  • Diverse ports, four service slots, up to 128 x 100GE QSFP28 ports or 64 x 100GE QSFP28 and 16 x 400GE QSFP-DD ports
Various ports, up to 128 x 100GE ports or 64 x 100GE ports and 16 x 400GE ports, which are fit for different scenarios of data center networks
and Zero Packet Loss
RG-S6920-4C
100GE/400GE ports
Expansion Module Slots
Four expansion module slots, each supporting the line card with up to 32 × 100GE ports
Four power supply modules
Six fan modules
25.6 Tbps
8000 Mpps
4094
RG-S6920-4C
(W × D × H)
About 34.25 kg (75.51 lbs., including all line cards, power supply modules, and fans)
RG-S6920-4C
Maximum Power Consumption
● Max: 1950 W
● Typical: 1469 W
● Static: 516 W
AC
RG-PA1200I-F
High-voltage DC
Input voltage range: 180 VDC to 300 VDC
RG-S6920-4C
Working altitude
RG-S6920-4C
L2 Protocols
IEEE802.3ad (Link Aggregation Control Protocol), IEEE802.1p, IEEE802.1Q, IEEE802.1D (STP), IEEE802.1w (RSTP), IEEE802.1s (MSTP), IGMP Snooping, MLD Snooping, Jumbo Frame (9 KB), IEEE802.1ad (QinQ and selective QinQ), GVRP
L3 Protocols (IPv4)
IPv6 Basic Protocols
Data Center Features
M-LAG
RDMA
OpenFlow 1.3
sFLOW sampling
INT
Standard IP-based ACL、Extended MAC-based ACL、Extended IP-bsaed ACL、Expert-level ACL、ACL 80、IPv6 ACL、Ingress/Egress ACLs、ACL Logging、ACL Counter (Ingress and egress counters are supported in interface or global configuration modes)、ACL Re-marking、Global ACL、ACL-based Redirection、Displaying ACL Resources、Processing First Packet of TCP Handshake When Binding the ACL to Restrict SIP、Matching Against 5-Tuple of Pass-by VXLAN Inner IP Packets、The expert-level ACL supports matching the IP flag and DSCP fields of VXLAN inner packets
HA Design
Security Features
Network Foundation Protection Policy (NFPP), CPP, DDoS attack defense, illegitimate data packet detection, data encryption, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, uRPF, broadcast packet suppression, DHCP Snooping, ARP spoofing prevention, ARP check, and hierarchical user management
Management Mode
SNMP v1/v2c/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, Syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm function, temperature alarm function, and configuration rollback
Specification
RG-S6920-4C
● EN IEC 62368-1
● BS EN IEC 62368-1
● UL 62368-1
● CSA C22.2#62368-1
● EN IEC 61000-3-3
● ETSI EN 300 386
● EN 300 386
● ICES-003 Issue 7
● ICES-003 Issue 6
● ANSI C63.4-2014
● AS/NZS CISPR 32
● CISPR 32
The configuration procedure for the RG-S6920-4C switch is as follows:
  • Select the switch.
  • Select expansion modulesbased on business requirements.
  • Select Optical Transceivers based on port requirements.
    RG-S6920-4C
    Four expansion slots, four power supply module slots, and six fan module slots
    The power supply module model is RG-PA1200I-F and the fan model is M2EFAN I-F.
    RG-PA1200I-F
    Power supply module, supporting 2+2 redundancy, hot swapping, and front-to-rear ventilation design
    M2EFAN I-F
    Fan module, supporting 5+1 redundancy, hot swapping, and front-to-rear ventilation design
    M6900-32CQ
    32 x 100GE ports
    M6900-16CQ4QC
    16 × 100GE optical ports (QSFP28) + 4 × 400GE optical ports (QSFP-DD)
    400G-QDD-DR4-SM1310
    400G-QDD-FR4-SM1310
    400G-QDD-SR8-MM850
