RG-SF2920U-8GT1MS Przełączniki - 1
RG-SF2920U-8GT1MS Przełączniki - 2
RG-SF2920U-8GT1MS Przełączniki - 3
RG-SF2920U-8GT1MS Przełączniki - 4
RG-SF2920U-8GT1MS Przełączniki - 5
RG-SF2920U-8GT1MS Przełączniki - 6
  • Various port combinations, rate increase, surge protection greater than 8 kV, 8 x 10/100/1000BASE-T ports, supporting PoE/PoE+, and 1 x 1GE/2.5GE SFP port for uplink
This switch provides 8 x 10/100/1000BASE-T ports, 1 x 1GE/2.5GE SFP uplink port, rich interfaces, supporting full service expansion.
More Stable Data Forwarding
2 x 1G/2.5GBASE-T ports
2 x 1GE/10GE SFP+ ports
16 x 10/100/1000BASE-T ports
2 x 1GE SFP ports
2 x 1GE SFP ports
System switching capacity *2
1 MB
256 MB
512 MB DDR3
1.5 MB
56.5 Mpps
76 Gbps
256 MB
512 MB DDR3
1.5 MB
1.18 kg (2.6 lbs)
1.43 kg (3.15 lbs)
1.74 kg (3.84 lbs)
1.97 kg (4.34 lbs)
2.04 kg (4.5 lbs)
2.81 kg (6.19 lbs)
2.34 kg (5.16 lbs)
2.33 kg (5.14 lbs)
2.33 kg (5.14 lbs)
Fixed power supply: 70 W
Fixed power supply: 150 W
The maximum power is 45 W
8.5 W
10 W (without PoE load)
55 W (full PoE load)
16.5 W (without PoE load)
141.5 W (full PoE load)
25 W (without PoE load)
150 W (full PoE load)
RG-SF2920 Series
Air discharge: 15 kV
Contact discharge: 8 kV
RG-SF2920 Series
RG-SF2920U
RG-SF2920
CWDM
XG-SFP-LR(A1-4)-H
XG-SFP-LR(A1-8)-H
GE-SFP-LR(A1-4)-H
GE-SFP-LR(A1-8)-H
