RG-S5310-48GT4XS-E Przełączniki - 1
RG-S5310-48GT4XS-E Przełączniki - 2
RG-S5310-48GT4XS-E Przełączniki - 3
RG-S5310-48GT4XS-E Przełączniki - 4
RG-S5310-48GT4XS-E Przełączniki - 5
RG-S5310-48GT4XS-E Przełączniki - 6
RG-S5310-48GT4XS-E Przełączniki - 7
RG-S5310-48GT4XS-E Przełączniki - 8
RG-S5310-48GT4XS-E Przełączniki - 9
RG-S5310-48GT4XS-E Przełączniki - 10
RG-S5310-48GT4XS-E 48-Port GE Layer 3 Managed Access Switch, 4-Port 10GE Uplink
  • Rich port types, 48 x 10/100/1000BASE-T ports for access, 4 x 1GE/10GE SFP+ ports for uplink
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
RG-S5310-24GT4XS-P-E
RG-S5310-48GT4XS-P-E
24 x 1GE SPF ports
48 x 1GE SPF ports
RG-PD150IB-F
RG-PA70IB
RG-PD150IB-F
RG-PA70IB
RG-PD150IB-F
RG-PA70IB
RG-PD150IB-F
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
3 MB
4,000/16,000 (authorized)
2,000/8,000 (authorized)
8,000/12,000 (authorized)
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
4.0 kg
(8.82 lbs)
(9.48 lbs)
4.2 kg
(9.26 lbs)
(9.92 lbs)
(9.48 lbs)
4.6 kg
(10.14 lbs)
6.20 kg (13.67 lbs)
6.50 kg (14.33 lbs)
6.38 kg (14.07 lbs)
6.58 kg (14.51 lbs)
6.78 kg (14.95 lbs)
6.69 kg (14.75 lbs)
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
RG-PA150IB-F (AC input)
RG-PD150IB-F (DC input):
RG-PA70IB (AC input):
● Maximum input current: 2 A
RG-PA70IB: 70 W
RG-PD150IB-F: 150 W
RG-PD150IB-F: 150 W
55 W
85 W
108 W
65 W (without PoE load)
810 W (full PoE load)
75 W (without PoE load)
1,570 W (full PoE load)
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
27°C (80.6°F): 34.3 dB
45°C (113°F): 56.5 dB
27°C (80.6°F): 40.8 dB
45°C (113°F): 52.4 dB
27°C (80.6°F): 38.9 dB
45°C (113°F): 53.7 dB
27°C (80.6°F): 51.6 dB
45°C (113°F): 57.4 dB
45°C (113°F): 58.3 dB
Air discharge: 8 kV
Contact discharge: 6 kV
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
RG-S5310-E Series
OSPFv2, OSPFv3, and GR
Basic LACP
Inter-VSU AP
Hot swapping of power modules
SPAN, RSPAN and ERSPAN
CLI (Telnet/Console)
VXLAN (authorized)
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
Power Module
RG-PA70IB
70 W AC power module
RG-PD150IB-F
150W DC power module
License
RG-VXLAN-MPLS-ENTRY-LIC
Optical Transceivers
