RG-S5300-24GT4XS-P-E Przełączniki - 1
RG-S5300-24GT4XS-P-E Przełączniki - 2
RG-S5300-24GT4XS-P-E Przełączniki - 3
RG-S5300-24GT4XS-P-E Przełączniki - 4
RG-S5300-24GT4XS-P-E Przełączniki - 5
RG-S5300-24GT4XS-P-E Przełączniki - 6
RG-S5300-24GT4XS-P-E Przełączniki - 7
RG-S5300-24GT4XS-P-E Przełączniki - 8
RG-S5300-24GT4XS-P-E Przełączniki - 9
RG-S5300-24GT4XS-P-E Przełączniki - 10
RG-S5300-24GT4XS-P-E Przełączniki - 11
RG-S5300-24GT4XS-P-E Przełączniki - 12
RG-S5300-24GT4XS-P-E Przełączniki - 13
RG-S5300-24GT4XS-P-E Przełączniki - 14
RG-S5300-24GT4XS-P-E Przełączniki - 15
RG-S5300-24GT4XS-P-E Przełączniki - 16
RG-S5300-24GT4XS-P-E Przełączniki - 17
RG-S5300-24GT4XS-P-E 24-Port GE Electrical Layer 3 Managed PoE Access Switch, 10G Uplink
  • Rich port types, PoE+ supported, 24 x 1000 Mbps Ethernet ports,4 x 10G optical ports for uplink
24 x 1000 Mbps electrical ports and four 10G optical ports for flexible networking PoE+ supported, providing power to powered devices on security hybrid systems and
wireless coverage systems
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
3 MB
Number of VRFs
*2 means the system's switching.capacity.
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
Maximum input current: 2 A
● Rated input voltage: 100 V to 240 V AC, 50 Hz to 60 Hz
55 W
65 W (without PoE load)
410 W (full PoE load)
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
2.7 kg (5.95 lbs)
3.0 kg (6.61 lbs)
3.0 kg (6.61 lbs)
3.83 kg (8.44 lbs)
4.20 kg (9.26 lbs)
4.60 kg (10.14 lbs)
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
Storage altitude: –500 m to 5,000 m (0 ft. to 16,404.20 ft.)
Operating altitude: –500 m to 5,000 m (0 ft. to 16,404.20 ft.)
27°C (80.6°F): 40.9 dB
45°C (113°F): 48.8 dB
27°C (80.6°F): 40.3 dB
45°C (113°F): 53.1dB
27°C (80.6°F): 33.5 dB
45°C (113°F): 53.9 dB
Air discharge: 8 kV
Contact discharge: 6 kV
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
RG-S5300-E Series
OSPFv2 and OSPFv3
Routing policy
IPv4/VRF
RADIUS
CLI (Telnet/Console)
SNMP v1/v2c/c3
RG-S5300-24GT4XS-P-E:
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
XG-SFP-T
