Service port
24 x 10/100/1000BASE-T Ethernet ports with auto-negotiation, 4 x 2.5G/1G SFP ports
Management port
68 Gbps
Forwarding rate
Capacity of MAC address table
2 x fan module
Cooling mode
Fan cooling
Input power
Rated input voltage range: 100V AC to 240V AC, 50/60Hz Max. input voltage range:90V AC to 264V AC, 50/60Hz
Power consumption
403W (PoE budget: 370W)
10 kV
440 mm × 292 mm × 43.6 mm (17.32 in. x 11.50 in. × 1.72 in.)
Operating temperature: 0°C to 45°C (32°F to 113°F) Storage temperature: –40°C to +70°C (–40°F to +158°F)
Warranty
3 years
Killer Layer 2+ Access Switch
Applications
and Uninterrupted Connection
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
RG-S2915-10GT2MS-P-L
Fixed Service Ports
24 ×
4 × 2.5G/1GE SFP ports
2 × 2.5GE/1GE SFP ports
Power modules
1 fixed power module
Fans modules
2 fixed fans
2 fixed fans
1 fixed fans
116Gbps
68Gbps
68Gbps
30Gbps
MAC Table Capacity
Flash Memory
64 MB
< 30 W
< 15.6 W
< 33 W (non-PoE)
< 403 W (PoE full load)
< 16 W (non-PoE)
< 141 W (PoE full load)
≤ 37 dB
≤ 39 dB
≤ 37 dB
Power port: 6 kV/2 kV
Telecom port: 10 kV
Telecom port: 10 kV
Telecom port: 10 kV
Telecom port: 10 kV
IEEE 802.1Q (4,094 VLANs)
Port based VLAN
SSHv1, SSHv2
IGMP V1,V2 snooping
Temperature Monitoring
Temperature Alarm
Overtemperature Protection
TFTP client
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
加载失败
TOP
