RG-PF2920U-4GT1MS-P Przełączniki - 1
RG-PF2920U-4GT1MS-P Przełączniki - 2
RG-PF2920U-4GT1MS-P Przełączniki - 3
RG-PF2920U-4GT1MS-P Przełączniki - 4
RG-PF2920U-4GT1MS-P Przełączniki - 5
RG-PF2920U-4GT1MS-P
Compact Size Compact Size
Fanless Design Fanless Design
Find out details >>
RG-PF2920U-4GT1MS-P
RG-PF2920-DPBOX-P
1 x 1000M/2.5G SFP port
1 x GE SFP port
9.7 Mpps
SFP port
Rated current: 1.3 A
Rated current: 0.75 A
Leakage current to ground
≤ 3.5 mA
EEE
1 x downlink POE/POE+ port
Overall power consumption
Without PoE load: ≤ 15 W
With PoE full load: ≤ 75 W
Without PoE load: ≤ 3 W
Overall power (PoE+) ≤ 33 W
10% to 90% RH
10% to 90% RH
5% to 90% RH
5% to 95% RH
GB/T9254.1
GB/T9254.1
Safety standard
GB 4943.1
GB 4943.1
Dimension (W x D x H)
RG-PF2920U-4GT1MS-P
RG-PF2920-DPBOX-P
4K IEEE 802.1Q VLANs
Password protection
EEE
APD port sleeping
IoT MQTT
Syslog/Debug and SNTP
RG-PF2920U-4GT1MS-P
RG-PF2920-DPBOX-P
