Diverse access rates: 5 Gbps/2.5 Gbps/1 Gbps/100 Mbps Multiple power modes: PoE/PoE+/PoE++ 4 x 25GE SFP28 ports and 2 x 40GE QSFP+ ports for uplink, enabling flexible networking and high-performance campus networks
RG-CS86-24MG4VS-UP |
RG-CS86-48MG4VS2QXS-UPD |
RG-CS86-24XMG4XS4VS-UPD |
RG-CS86-12XMG4VS-UP |
Fixed Service Port |
24 x 100M/1000M/2.5GE/5GE/10GE electrical ports with auto-negotiation 4 x 1GE/10GE SFP+ ports 4 x 10GE/25G SFP28 ports
Fan modules |
2 fixed fans |
3 modular fans |
3 modular fans |
2 fixed fans |
Power modules |
1 Built-in power module |
Fixed Management Port |
Switching Capacity |
440 Gbps/2.56Tbps |
840 Gbps/2.56Tbps |
760Gbps/2.56Tbps |
440 Gbps/2.56Tbps |
Packet Forwarding Rate (Actual) |
327 Mpps |
625 Mpps |
565 Mpps |
327 Mpps |
MAC Table Capacity |
32,768 |
ARP table |
16,000 |
IPv4 Unicast Routes |
16,000 |
IPv4 Multicast Routes |
4,000 |
IPv6 Unicast Routes |
16,000 |
IPv6 Multicast Routes |
2,000 |
ACL entries |
In: 2,500 Out:1,000 |
3.65 kg (8.82 lbs) |
6.11 kg (13.47 lbs) |
3.65 kg (8.82 lbs.) |
Typical Power Consumption |
Power Module Model |
RG-PA600I-P-F RG-PA1000P-F |
Rated Input Voltage |
Built-in power module AC input Rated voltage range: 100 V AC to 240 V AC Maximum voltage range: 90 V AC to 264 V AC Frequency: 50/60 Hz Rated current per circuit: 6 A |
Available model: RG-PA600I-P-F AC Input Rated voltage range: 100 V AC to 240 V AC Maximum voltage range: 90 V AC to 264 V AC Frequency: 50/60 Hz Rated current per circuit: 8 A
Available model: RG-PA1000I-P-F AC Input Rated voltage range: 100 V AC to 240 V AC Maximum voltage range: 90 V AC to 264 V AC Rated current per circuit: 8 A |
PoE-capable Port |
Surge Protection |
6 kV |
6 kV |
6 kV |
6 kV |
Temperature Monitoring |
Temperature alarm |
Temperature alarm |
Temperature alarm |
Temperature alarm |
Operating Temperature |
0°C to 45°C (32°F to 113°F) |
Storage Temperature |
Operating Humidity |
Storage Humidity |
Software Specifications |
Ethernet Switching |
Super VLAN, Private VLAN |
Basic QinQ Flexible QinQ |
STP, RSTP, and MSTP |
LACP (IEEE 802.3ad) |
IP Service |
ARP |
DHCP snooping |
DHCPv6 snooping |
IP Routing |
BGP4 and BGP4+ |
IPv4 and IPv6 PBR |
ECMP |
IGMP v1/v2/v3 snooping |
PIM-DM, PIM-SM, and PIM-SSM |
MSDP |
MLD v1/v2 |
MLD snooping v1/v2 |
PIM-SMv6 and PIM-SSM v6 |
Port traffic rate limiting |
Multiple AAA modes |
RADIUS and TACAS+ |
HTTPS |
SSHv1, SSHv2 |
Global IP-MAC binding |
SAVI |
REUP, RLDP, DLDP |
BFD |
GR for RIP, OSPF, BGP |
1+1 power redundancy |
SPAN, RSPAN, and ERSPAN |
sFLOW |
NTP and SNTP |
FTP and TFTP |
SNMP v1/v2/v3 |
RMON (1, 2, 3, 9) |
NETCONF |
Cloud and SON |
RG-PA600I-P-F |
600 W AC power module |
RG-PA1000I-P-F |
1000 W AC power module |
GE-SFP-LX20-SM1310-BIDI |
GE-SFP-LX20-SM1550-BIDI |
GE-SFP-LH40-SM1310-BIDI |
GE-SFP-LH40-SM1550-BIDI |
VG-SFP-SR-MM850 |
VG-SFP-LR-SM1310 |
VG-SFP-AOC5M |
40G-QSFP-SR-MM850 |
40G-QSFP-LR4 SM1310 |
40G-AOC-5M |
40G-AOC-10M |
