RG-S5000-24GT4MS-E Przełączniki - 1
RG-S5000-24GT4MS-E Przełączniki - 2
RG-S5000-24GT4MS-E Przełączniki - 3
RG-S5000-24GT4MS-E Przełączniki - 4
RG-S5000-24GT4MS-E Przełączniki - 5
RG-S5000-24GT4MS-E Przełączniki - 6
RG-S5000-24GT4MS-E Przełączniki - 7
RG-S5000-24GT4MS-E Przełączniki - 8
RG-S5000-24GT4MS-E Przełączniki - 9
RG-S5000-24GT4MS-E Przełączniki - 10
RG-S5000-24GT4MS-E Przełączniki - 11
4 x 1GE/2.5GE SFP ports
1 x RJ45 console port and 1 x USB port
System packet forwarding rate
440 mm × 220 mm × 43.6 mm (17.32 in. × 8.66 in. × 1.72 in.)
Warranty
3 years
RG-S5000-24GT4MS-E
Local & Cloud O&M
Visualized Management
Alarm Processing
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
RG-S5000-10GT2MS-P-E
RG-S5000-24GT4MS-P-E
10 x 10/100/1000BASE-T ports
2 x 1GE/2.5GE SFP ports
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
27 Mpps
104 Mpps
27 Mpps
139 Gbps
64 MB
64 MB
64 MB
64 MB
64 MB
512 MB DDR4
512 MB DDR4
512 MB DDR4
512 MB DDR4
512 MB DDR4
256
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
2.0 kg (4.41 lbs)
2.40 kg (5.25 lbs)
3.70 kg (8.15 lbs)
3.60 kg (7.94 lbs)
3.18 kg (7.01 lbs)
4.13 kg (9.11 lbs)
Mounting
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
Fixed power supply: 16 W
Fixed power supply: 15.6 W
Fixed power supply: 30 W
Fixed power supply: 141 W
Fixed power supply: 430 W
16 W
16 W (without PoE load)
141 W (full PoE load)
33 W (without PoE load)
403 W (full PoE load)
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
27℃ (80.6°F): 40 dB
27℃ (80.6°F): 40 dB
27℃ (80.6°F): 40 dB
Air discharge: 8 kV/15 kV
Contact discharge: 6 kV/8 kV
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
RG-S5000-E Series
Port-based VLAN assignment
Basic QinQ and selective QinQ
DNS client
Neighbor Discovery (ND)
Expert ACLs
Port rate limiting
IEEE 802.1X authentication
Proxy ARP and ARP entry aging
Hardware CPP and NFPP
Load balancing modes
TFTP (TFTP client)
SSH v1.5/v2.0
Cloud
WIS
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
Which RG-S5000-E series switches with PoE power supply are recommended?
The RG-S5000-10GT2MS-P-E and RG-S5000-24GT4MS-P-E are recommended. They provide up to 30 W power per port to meet power supply needs of terminals such as VoIP phones, IP cameras, and access points (APs).
108
Because our equipment room is near meetings rooms, we are concerned about noises caused by switches. Can we use the RG-S5000-10GT2MS-E switch in such a scenario?
Yes, the RG-S5000-10GT2MS-E switch adopts a fanless design and natural heat dissipation without noise. Even if your office is near the equipment room, you are free of worries about noises. The switch also supports energy efficient Ethernet (EEE). Idle ports are shut down automatically to save power.
107
Are 2.5GE SFP ports of the switch backward-compatible?
Yes. The 2.5GE SFP ports of the switch are compatible with SFP transceiver modules and backward-compatible with 1000 Mbps.
108
加载失败
TOP
