Zdjęcie
XS-S1930J-24GT4SFP/2GT-P
Small-size, compact, fanless quiet design, suitable for industries with limited device storage space such as apartments and hotels
Modele
Seria
Charakterystyka
  • Small size and personalized design, flexible deployment in small space
  • No fan, natural heat dissipation, quiet and energy saving
  • Various security protection policies, stable and reliable operation of equipment
  • Unified management on the cloud platform, simpler and easier O&M
High reliability:
STP/RSTP/MSTP
LLDP/RLDP
Load Balancing
Application protocols
DHCP CLIENT
TFTP
Telnet
MIRRORING
Management features
SNMP
SYSLOG/DEBUG
Web management
Japanese cloud management
CLI
SSH
Security features
Port Security (IPv4 + MAC Binding)
DHCP SNOOPING
Protection Port
Storm Suppression
IGMP Snooping v1/v2
SSL
24-port 1000M layer-2 managed access-layer PoE switch
Small size, quiet, highly cost-effective and universal, widely used in scenarios like rental apartments, small and medium-sized hotels, and small and medium-sized enterprise SOHO offices.
Applications
Small size, easy and flexible installation in junction box in a corridor or on the desktop in a room, and more convenient networking.
CPU protection policy
CPU Protection Policy (CPP) is supported to control the types of packets sent to the CPU and the traffic volume, and protect the CPU usage.
Web GUI management and MACC cloud management are supported. Auto configuration on cloud, remote restart, diagnosis and management are available. Administrators can learn the network conditions anytime anywhere without going to the scene frequently.
Going online with zero configuration
Clear device data at a glance
Remote restart and diagnosis
Ruijie Networks
